Thierry_S
JMP > Multiple Response Modeling > Retrieve List of Individual Responses
Hi JMP Community,
JMP 17.2 on Windows 10
I have a Table listing Pathways and their constituents (Overlap_gene) with a Multiple Response modeling type from a publication.
How can I assemble a list of all unique entries in the Overlap_gene from this table?
Of note, the Data Filter tool provides the breakdown of unique entries as desired, but I have not figured out how to retrieve them as a list.
Thank you,
Best,
TS
Thierry R. Sornasse
Re: JMP > Multiple Response Modeling > Retrieve List of Individual Responses
One option is to use Distribution and extract the values from the Frequencies table by making a data table
dist = dt << Distribution(Multiple Response Distribution(Column(:overlap_genes)));
dt_vals = Report(dist)["Frequencies", Table Box(1)] << Make Into Data Table;
vals = dt_vals[0,1];
close(dt_vals, no save);
dist << Close Window;
show(vals);
show(vals);
Level XIII
ver< elegant!
Another option: split the entries into multiple columns, stack them and the calculate a summary:
dt = current data table();
n1 = ncols(dt);
dt << Text to Columns( columns( :overlap_genes ), Delimiters( ",", " " ) );
n2 = ncols(dt);
dtstack = dt << Stack(
	columns(Eval(n1+1 ::  n2)),
	Drop All Other Columns( 1 ),
dtstack << Select Where( :Data == "" ) << Delete Rows;
dtstack << Summary(	Group( :Data ));
