danielgri17
JMP crashing when opening
Hello all!
I started JMP pro 13 not long ago, however i am having some noobie troubles. I have only done a few scripts, however now whenever i open JMP it crashes and closes itself after starting it, regardless if i open a new file or an existing one. I already tried uninstalling the program and installing it again, as well as the solution mentioned here , however the program keeps on crashing. I would appreciate any advice, it is getting very frustrating and i have already all my data in JMP scripts so i really need to access to keep on working on it. Thanks a lot!
Jeff_Perkinson
Re: JMP crashing when opening
Contact our Tech Support department, [email protected].
They can help diagnose and correct the problem.
-Jeff
