JMP connectivity with Microsoft Azure Blob Storage
Jun 12, 2026 02:24 PM(513 views)
Does JMP have a way to batch results from Azure Blob Storage? I remember there was a feature called a like a query tool to build an output from a database. Any suggestions would be greatly appreciated, thanks!
It looks like azure blobs can be accessed via URLs which you can use with open() or loadTextFile() in JSL and possibly with File->Open.
If there is security (password) you might want to use something like https://pypi.org/project/azure-storage-blob/ , just looked it up and don't know how well it works. You'd write a small python program and call that from JMP.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '953596' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '953596') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '953596') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
