JumpingAC
JMP and MongoDB
Our database team is moving us from a T-SQL framework to a MongoDB framework. Currently much of our team has extensive JMP scripts and tools for automated queries / processing / analysis that rely on JMP's ability to connect/pull through the OBDC drivers.
What does JMP / MongoDB integration look like? Below is a 'sample' of how we interact currently. Is this functionality still avaliable with the MongoDB system?
S=evalinsert("SELECT
dt1 =       Open Database(
"DSN=SQL;Description=SQL;UID=;Trusted_Connection=Yes;APP=JMP;WSID="||user||";DATABASE=SQL",
     S,
     "Results from " || Char( startdate ) || " to " || Char( enddate ) || ""
Phil_Brown
Re: JMP and MongoDB
Hi JumpingAC,
I too am on a similar path. Haven't actually integrated yet fully. But as far as I know once there's an ODBC driver available, JMP can use it. There are other options as well where no DSN is required.
Also with JMP 14's new parsing functions, building JSON and XML expression are much easier.
See: https://community.jmp.com/t5/Discussions/Efficient-Construction-of-XML-and-JSON/m-p/53875/highlight/...
among others.
PDB
JumpingAC
Re: JMP and MongoDB
That looks very helpful. I was also just infomed we'll be taking adjantage of the MongoDB Connector ( https://docs.mongodb.com/bi-connector/master/ ) which will provide the JMP / SQL / Database connections.
I was hoping there was a way to easily parse a MongoDB native JavaScript bit of code within a JMP script.
