JMP Script to detect the rows which are excluded in the data table ?
Hi all,
may I ask,
is JMP Script able to detect the rows which are excluded in the data table and remove them automatically  ?
Re: JMP Script to detect the rows which are excluded in the data table ?
Here is the example script taken directly from the Scripting Index
     Help==>Scripting Index
dt << Select Rows( [5, 7, 8, 10, 15] );
dt << Exclude( 1 );
dt << Clear Select;
Wait( 2 );
dt << Select Excluded;
// This line is added from the Delete Rows option in the Scripting Index
dt << Delete Rows;
So the actual script you want is
dt << Delete Rows;
dt << Exclude( 1 );
dt << Clear Select;
Wait( 2 );
dt << Delete Rows;
dt << Delete Rows;
Thank you, Jim.
This is what I am looking for.
msharp
Selecting Rows changes the state of your table, granted so does deleting rows so it's a mute point for your problem.  However, if you are interested in doing other things to these rows I would also suggest the get excluded rows function.
ex_rows = dt << Get Excluded Rows;
