Hello All,
I am trying to create new columns for every number value that comes after |90= and label the columns as the string that comes before |90, so the pX or whatever else comes before it. See attached photo below as example.
So, in the first row, I'd like to grab that 93 that comes after "p1|90=", and make a new column labelled "p1". I'd like to do that every number that comes after any and all "pX|90=". That pX might also be sX or rX or pXa/b/c/...and so on. So I'd also like to make new columns for those values as well. The number of data points per row varies greatly, from just one(1) pX|90= value to 15 different pX|90=values, perhaps with some values with sX|90= or rX|90=.
I was using the Word function that grabbed pX|00 data values. Now I want to grab just 90, and tried using the previous script I was using for that but found that it wasn't grabbing all of the values I wanted.
This is for hundreds, soon to be thousands, of rows, so manually doing this isn't tenable.
What function(s) makes sense to use here?
I am new to JMP scripting, am willing to learn and listen to any ideas. Thank you!
