Aadit
JMP Project script
i have written a couple of script which is specific for JMP Project application. I dont want the script to run if not opened in project and executed. Is there any way to achieve this .. Kindly guide.
my idea was get current window check is its a project or something in that line.
Re: JMP Project script
Get Project List() and This Project() functions should be able to get you what you want.  Look in the Scripting Index for  definition and examples.
