ComplexNerd
JMP Project - Run script on start
Hello guys,
I have a script stored in jmp project's content. I want the script to run when the project starts. also if i have a script saved in datatble which is in project content how to run that also automatically.
Additionally i want to dock the window generated by the script automatically where i specify. Is this possible, Kindly guide
Thanks in advance
Re: JMP Project - Run script on start
In the project window, go to Project=>Settings and there you will see an On Open script box that you can place a script into.
Concerning a Table Script that run when a data table is opened, create a table script and name it "On Open" and it will run when the data table is opened.
ComplexNerd
@txnelson Thank you it works fine..
But is there anz waz to lock the docking of the window that is opened bz this script. Like i want to dock this window alwazs to the right so that other componsents dosent get distrubed.
If there is, a way to lock the docking of the window, I am not aware of how to do that.  Possibly another member knows how to.
Stefan
Can "Project=>Settings - On Open" be accessed through JSL? I have a (project specific - so can't do template) "project setup" script that I run with every new project, and I would like to populate the "on open" automatically when each new project is created...
