djhanson
JMP Prefences - Windows Specific ones are not settable?
Hi, within the JMP Preferences window, using JMP14 and Windows 10, there is a subset of preferences under "Windows Specific".  This includes for example "Graphics scale factor %" which should be defaulted to 100.
When I do Get Preferences() in JSL none of the "Windows Specific" ones like the above one show up.  Are any of these "Windows Specific" ones able to be set with Set Preferences() or some other method?
DJ
Re: JMP Prefences - Windows Specific ones are not settable?
Apparently not. See the note with this help entry.
