- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Get Direct Link
JMP Journal adding graphs JSL
Hello Everyone,
I have one control chart graph with column switcher on the side to change the graph that I want to look at. I want to be able to use JSL to copy over the control chart to the journal and then use the column switcher to pick a different control chart graph and move that one over too. The point is to be able to move over any of the control chart graphs you want to look at into the journal quickly using a script so that I have a record of the control charts I have wanted to look at. I have tried to look around at different discussions and have not been able to find anything for this. Any help would be greatly appreciated.
Thank you for your time,
-Ryan
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Re: JMP Journal adding graphs JSL
If you are using the interactive Column Switcher feature, then why not use the interactive command to journal the current chart? Select Edit > Journal or press Control-J on Windows or Command-J on Mac.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Here is a sample script that adds a chart every time the column switcher is changed.
dt = Open( "$SAMPLE_DATA/Process Measurements.jmp" );
new window("The Journal", <<journal);
gb = Control Chart Builder(
Size( 528, 458 ),
Show Limit Summaries( 0 ),
Variables( Y( :Process 1 ) ),
Chart( Position( 1 ) ),
Dispatch(
{"Process 1 Limit Summaries", "Process Capability Analysis", "Histogram"
"Process Capability Analysis Histogram",
FrameBox,
{Frame Size( 320, 20 )}
columnSwitcher = gb <<
Column Switcher(
:Process 1,
{:Process 1, :Process 2, :Process 3, :Process 4,
:Process 5, :Process 6, :Process 7}
pre = Function( {currentColumn, nextColumn, switcher},
dummy=1;
post = Function(
{previousColumn, currentColumn, switcher},
current report()["Control Chart Builder"]<<journal;
columnSwitcher <<
Make Column Switch Handler( pre,post );
// The below line was added to ensure the first chart is automatically
// moved to the journal
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
@Mark_Bailey . Thank you I completely forgot about this short cut!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Size( 528, 458 ),
Dispatch(
FrameBox,
Column Switcher(
:Process 1,
dummy=1;
post = Function(
columnSwitcher <<
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
@txnelson . Thank you for your help! This will work great.
