Hi @LouisAltamura ,
Do you have an annotation file for the RNA-seq data? Sometimes when the data is mapped to the transcript level, there is an annotation file that gets created that might also map to the gene level (gene symbol or entrez gene ID). If you only have the transcript IDs, how do you know which transcripts belong to which gene? Maybe that source can be used for the annotation file or better yet, that column of information can be merged into the main transcript data file.
You can always do DEG at the gene level, if that is what you are looking for. There is a mechanism for that in JMP Genomics. You can add the gene ID as the By Variables item instead of the transcript ID. You can put the transcript ID at the row level category variables section. The transcripts will be averaged for that gene then that gene will be used for DEG.
If you are only looking to have JMP Genomics export the results with the transcript data along with a Gene ID and let the next software do the averaging for you, then an annotation file will be needed.
Another thought, if you have the public IDs for the transcripts, then something like the UCSC genome browser can be used to get the transcript IDs and the gene IDs for that species. That can then be used to merge into the transcript data. Then use the gene ID as the By Variables section if you are using the ANOVA platform.
If you are using the RNA-Seq workflow, then you would not be able to specify the gene ID as the level of the analysis you wanted. However, there is a utility called Statistics for Columns under SAS Data Set Utilties>Columns where you can use the gene ID as the Variables By Which to Summarize and the samples in the Variables to Be Summarized. You also get to choose how to summarize in the options tab: Mean, median, etc. But this does assume you have the transcript ID and gene ID in the same data set.
Chris Kirchberg, M.S.
2Data Scientist, Life Sciences - Global Technical Enablement
Tel: +1-919-531-9927 ▪ Mobile: +1-303-378-7419 ▪ E-mail:
[email protected]www.jmp.com
