JMP Chinese-english comparison
Does anyone have a Chinese-English comparison of JMP statistical terms?
Re: JMP Chinese-english comparison
Can you explain a bit more what you need?
Are you using a translated version of JMP currently?
Do you have questions about a particular point?
Are you looking at documentation, or the output of the JMP program?
Would you like to suggest alternative translations?
@shannon_conners
Byron_JMP
On the PC version of JMP, In the preferences menu, there is language option somewhere.    I switched to Chinese one time, just to see what would happened and had a devil of a time figuring out how to get back because everything was in Chinese.
Right, you can see the English version from a localized version via an option in the prefs.
