- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Get Direct Link
JMP Alert: Subscript Range at row 66 in access or evaluation of 'selected_pqa[/*###*/i]', selected_pqa[/*###*/i]
Hi JMP community,
I am having another issue with JMP scripting that is giving me the following error, even though I am getting the resulting output (charts and test results) I need:
Here is a partial JSL script that I think the problem lies:
nw2 = New Window( "Select PQAs",
<<Modal,
Text Box("Set PQA(s):"),
variablebox1_pqa = Check Box( unique_pqa ),
H List Box(
variablebox1_pqa_all = Check Box(
<<SetFunction(
function({this},
variablebox1_pqa << Set All( this << Get, run script( 1 ) )
Text Box(
"Select All PQAs",
<<Set Width( 90 ),
<<Set Wrap( 90 )
H List Box(
//get all saved variable values when the user
//selects the OK button from the menu
Button Box( "OK",
answers = Eval List({
selected_pqa = variablebox1_pqa << get selected
// nw << close window;
Button Box( "Cancel")
//change popup window size
<<Size Window(600,600)
// If cancel or red X was clicked, stop the script
If( nw2 == {Button( -1 )}, Stop() );
//Production of Output
//initialize a jmp report window
nw= New Window("JMP report results for each PQA",
container = V List Box()
//loop through each PQA and paste results into the
//initialized jmp report window at each iteration.
for (i = 1, i <= N Items(unique_pqa), i++,
content = V List Box(
pqa_val = selected_pqa[i];
dt << Select Where(:PQA == pqa_val);
//subset the selected data, but make subset data table pop-up invisible
listDT = dt << Subset(invisible,
output table name( "Subset where PQA is " || pqa_val ),
Selected rows only ( 1 ),
Selected columns only( 1 )
This is the window where I can select PQAs, or all PQAs. I do not get the alert when I select all PQAs. I get the alert when I select a handful of PQAs.
Can you help me resolve this alert?
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Re: JMP Alert: Subscript Range at row 66 in access or evaluation of 'selected_pqa[/*###*/i]', selected_pqa[/*###*/i]
Please replace unique_pqa with selected_pqa in
Otherwise the index i will get higher than N Items(selected_pqa
) - which leads to the error that you reported.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
I believe the issue is that you are looping in your For() loop, from 1 to N Items in unique_pqa, but you are doing your selection from selected_pqa. If you have 10 items in your Check Box(), and you only select 2 of them, there will be 8 Select Where() calls that are not selecting, and therefore your susets will not run correctly.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
