dntt
JMP 18 JSL cannot add spec to column property
My jsl to add spec to column properties failed on the new JMP 18. I've been using it successfully on JMP 17.
Eval(
	Eval Expr(
		dt:(collist[i])
			<< Set Property("Spec Limits", {LSL(Expr(LSL)), USL(Expr(USL)), Target(Expr(TARGET)), Show Limits(Expr(Show_Limit))})
			<< Set Property("Units",Expr(UNITS))
The "Spec Limits" property shown up in the column but there is no value (USL, LSL, Target) inside.
Hope someone can help.
Thank you.
Re: JMP 18 JSL cannot add spec to column property
Very difficult to say without seeing the whole code or any of the data. Are LSL and USL numbers? This example works in JMP18.0.0
LSL = 1;
USL = 3;
TARGET = 2;
Show_Limit = 1;
UNITS = "m";
collist = {:height, :weight};
i = 1;
Eval(
	Eval Expr(
		dt:(collist[i])
I ran your JSL without issue using JMP 18.1 on Windows 11.
dt =
// Open Data Table: Big Class.jmp
// → Data Table( "Big Class" )
LSL = 44;
target = 55;
USL = 66;
show_limit = 1;
Units = "LBS";
colList = dt << get column names(string,continuous);
i=1;
Eval(
	Eval Expr(
		dt:(collist[i]) << Set Property(
			"Spec Limits",
			{LSL( Expr( LSL ) ), USL( Expr( USL ) ), Target( Expr( TARGET ) ), Show Limits( Expr( Show_Limit ) )}
		) << Set Property( "Units", Expr( UNITS ) )
Are there any messages in the JMP Log?
LSL = 1;
USL = 3;
TARGET = 2;
Show_Limit = 1;
UNITS = "m";
i = 1;
Eval(
	Eval Expr(
		dt:(collist[i])
dt =
LSL = 44;
target = 55;
USL = 66;
show_limit = 1;
Units = "LBS";
i=1;
Eval(
	Eval Expr(
			"Spec Limits",
dntt
I figured out my mistake. There is some character inside the USL/LSL/Target columns of the spec file that messed up the datatype. I made sure USL/LSL/Target columns to be numeric/continuous and it works fine now.
Thanks all for checking.
