Owen
JMP 17 and Python
I was hoping to integrate python into JMP JSL (version 17.2). I need to do some complex nesting but I can't even seem to do something simple. The scripting index for Python Submit showcases python generating a variable and then it being pulled into JSL using Python Get.
//scripting index code
Python Init();
Python Submit( "\[
str = 'The quick brown fox jumps over the lazy dog';
a = 200;
getStr = Python Get( str );
getNum = Python Get( a );
Show( getStr, getNum);
Python Term();
I was hoping to start with something simple like this and then advance to something more advanced:
Python Submit("\[
for i in range(10):;
if i == 6:;
print(i);
I was expecting the terminal to solely print a six however after running the script the result was a bit bizarre.
//Terminal Output
if i == 6:;
print(i);
I have tested some more and learned that a couple of things work. But I still can't get nested loops to work.
//Code that seemingly works
Python Submit("print('Hello World')");
Python Submit("for i in range(10): print(i); print(i);");
//Code that doesn't work for some reason
Python Submit("for i in range(10):; if i == 6; print(i)");
Python Submit("for i in range(10): if i == 6: print(i)");
Python Submit("for i in range(10): if i == 6:; print(i););
If anyone has any advice it would be much appreciated.
Re: JMP 17 and Python
Here is the Submit structures in the JMP 17 interface to Python that I found that work
Python Init();
Python Submit("\[
for i in range(11):
   if i == 6:
      print(i)
      print(i)
Python Submit("i=6
if i == 6: print(i); print('i is 6')
Python Init();
Python Submit("\[
for i in range(11):
   if i == 6:
      print(i)
      print(i)
Python Submit("i=6
Owen
I didn't realize that indentation had such a large impact in jmp. Thanks for the help!
It doesn't have an impact in JMP but it does have an impact in Python (you are running Python code not JSL).
If you are able to update to JMP18 you will save yourself from a lot of possible headache due to the new way of handling Python in JMP.
mmarchandFSLR
Looks like you overlooked the indentations needed.
Python Submit("\[
for i in range(10):
	if i == 6:
		print(i)
]\");     //6 (then 0 when Python is successfully terminated)
