JMP 15 not compatible with JMP14 JSL
In JMP14, i am using code
r = dt << Get Rows Where( name("sex") == "M" );
But it does not work in JMP15.
I cannot change code at this point as it is used many places in the code.
have seen previously also with newer releases previous JMP JSL is not compatible, face the issue again.
r = dt << Get Rows Where( :sex == "M" );
Show( r );
6 REPLIES 6
Jeff_Perkinson
Re: JMP 15 not compatible with JMP14 JSL
I've just tested your code:
Show( r );
and I get the same results in JMP 14 and JMP 15.
Here's the log from JMP 14:
Show( r );
r = [6, 7, 8, 12, 13, 14, 15, 21, 22, 23, 24, 25, 26, 27, 30, 31, 32, 33, 34, 37, 39, 40];
and from JMP 15:
Show( r );
Can you give us some detail about what is failing for you? Is there an error message?
-Jeff
you need to test this: r = dt << Get Rows Where( name("sex") == "M" );
i tested again and got error again as below
Name Unresolved: sex{1} in access or evaluation of 'sex' , sex/*###*/
at line 3 in Scripting Index
Whole code as below
Show( r );
Jeff_Perkinson
My apologies. I missed the difference between the two code snippets in your original post.
However, I tested your code as posted immediately above in JMP 14 and JMP 15 and got the same result in both.
Log from JMP 14:
Show( r );
In the following script, error marked by /*###*/
r = dt << Get Rows Where( sex/*###*/ == "M" );
Show( r );
Log from JMP 15:
Show( r );
at line 3 in untitled script 4.jsl
-Jeff
jimloughlin
For what it is worth, I get the same results in v13.2.1.
Show( r );
Show( r );
Jim Loughlin
Loughlin Consulting
You should employ the : scoping operator to the Name( "sex" ) directive if you want to use it as a column name. This form works:
r = dt << Get Rows Where( :Name( "sex" ) == "M" );
