lala
Level IX
JMP能否实现在散点图中选定部分行数据后、自动按选定的数据重新作图?
例如用Big Class.jmp的身高、体重作散点图。选定部分数据、如图1
JMP能否自动将这个选定30行数据、重新作图生成图2:
谢谢专家
Re: JMP能否实现在散点图中选定部分行数据后、自动按选定的数据重新作图?
I'm not sure if JMP can do that by itself, but you can help JMP with Formula Column which will update row values if the row is selected (make  that column Nominal):
Selected(Row State())
Then use that column as a Local data filter in the new graph builder (you can also minimize the Local data filter):
I suggest checking out this video by @brady_brady: Special Formula Columns . It will show this trick and other useful tricks with some formula columns.
