SpannerHead
Iterate Row Legend
I need to investigate the cause of a pattern I'm seeing in a variability gage graph.  I want to iteratively check the input parameters, which are stored in columns of the data table.  Is there a way to iterate through those or an alternative way to assess their impact?
Slán
SpannerHead
Re: Iterate Row Legend
Could you use column switcher? You can use it to change one (or have few to change multiple) column(s).
Or modelling (partition analysis, predictor screening or many other options)
SpannerHead
Column switcher is a great application, very handy indeed.  Was hoping there was an equivalent for the row legend that I didn't have to code myself.
Slán
SpannerHead
