lala
Level IX
It's unexpected that the file merging speed of JMP Pro 14 is so much faster than that of JMP Pro 18
The speed of file splicing has slowed down since JMP Pro 18
I had to use JMP Pro14 again to operate.
dir="C:\0\";;Fs=Files In Directory(dir);
for(j=1,j<=N Items(fs),j++,
d1=Open(dir||fs[j],Add to Recent Files(0));na=d1<<Get Name();
if(j==1,d2=d1;d2<<setName("名2");,current data table(d2);d2<<Concatenate(Data Table(d1),Append to first table);Close(d1,nosave));
try(d2<<Delete Table Property("Source"));d2<<Save("D:\0\JMP\big.jmp");
Re: It's unexpected that the file merging speed of JMP Pro 14 is so much faster than that of JMP Pro 18
Hello Lala,
Have you tried putting Begin Data Update and End Data Update around the outside of your for loop? This example below is from the Scripting Index.
Brian Corcoran
JMP Development
dt << Begin Data Update;
dt << Add Rows( 2000 );
dt << End Data Update;
lala
Level IX
Hehe, I tried it — there's almost no difference compared to my original script in JMP Pro 18.
I did a quick test merging 200 files: the runtime consistently fell between 8.7 and 9 seconds across multiple runs.
However, the exact same code completes the task in only ~1.5 seconds on JMP Pro 14
Do your tables have table variables/table scripts? Table variables can cause massive issues if they get added as new columns.
lala
Level IX
None of my original files have Table Property("Source").
My habit is to set Subset();And dt<<Update();All the generated sources have been deleted
try(current data table()<<Delete Table Property("Source"));
This is purely a version issue and has nothing to do with the JSL code.
Conny_Wang
18版本开始好像前后端分离了,应该是用新的语言重构了软件,好多bug没修复呢,你试试 JMP19 看看卡不卡
lala
Level IX
Thanks! I'll try version 19.
