barnabei
Issue exporting tabbed report to html + data
Hi all,
I'm trying to script some analysis that creates a tabbed output, with each tab containing a chart generated in graphbuilder.  See attached example.  Would like to export for non-JMP users.  Can export to html but would prefer to export to html with data to preserve the format.  When I try this, the exported file opens but there is no data shown.  See example of output and script used (limited the script to just one of the 6 graphs generated):
New Window("Calibration Curves",
	tb = Tab Box(
		"Test 1",
		vlb1 = V List Box("Data Analysis"),
		"Test 2",
		vlb2 = V List Box("Data Analysis"),
		"Test 3",
		vlb3 = V List Box("Data Analysis"),
		"Test 4",
		vlb4 = V List Box("Data Analysis"),
		"Test 5",
		vlb5 = V List Box("Data Analysis"),
		"Test 6",
		vlb6 = V List Box("Data Analysis")
dtStand = dtSum;
dtStand << select where(:assay == "Test 1");
dtTest 1 = dtStand << subset(output table name("Test 1"));
gTest 1 = New Window("test",
	Graph Builder(
		Size(534, 482),
		Show Control Panel(0),
		Variables(X(:"Mean(Readbacks)"n), Y(:"Mean(calculated_net_mfi)"n)),
		Elements(Points(X, Y, Legend(5))),
			Dispatch(
				"Mean(Readbacks)",
				ScaleBox,
				{Scale("Log"), Add Ref Line(0.0031, "Solid", "Black", "LLoQ", 1),
				Add Ref Line(2.65, "Solid", "Black", "ULoQ", 1)}
			Dispatch({}, "Mean(calculated_net_mfi)", ScaleBox, {Scale("Log"), Inc(1), Minor Ticks(1)}),
			Dispatch(
				"Graph Builder",
				FrameBox,
				{Add Graphics Script(
					4,
					Description(""),
					Y Function(
						Test 1P4 + (Test 1P1 - Test 1P4) / (1 + (X / Test 1P3) ^ Test 1P2) ^ Test 1P5,
						X
vlb1 << append(gTest 1);
gTest 1 << close window;
Close(dtTest 1);
barnabei
Re: Issue exporting tabbed report to html + data
JMP Version is 17.0.0, Mac
