jlmbs
Is this possible to write a script that opens always the last sheet of an xlsx file?
I need a JSL script that opens always the last sheet of a chosen xlsx file. Is there a function to do this in JSL?
Alternatively, is it possible to accomplish this by compiling all the sheets of the Excel file into a list and open the last item of the list? Or open the excel file in a way that the user can input the sheet to open?
Re: Is this possible to write a script that opens always the last sheet of an xlsx file?
I've added a reference to the chosen file, which can then be plugged into Open().  Let us know if this works (the Open settings may need to be adjusted for your file):
sheetList = Get Excel Worksheets(file=Pick File("Select xlsx file","$DOCUMENTS",{"Excel File|xlsx", "All Files|*"},1,0,""));
Show( sheetList );
lastSheet = sheetList[N Items( sheetList )];
Open(
	file,
	Worksheets( lastSheet ),
	Use for all sheets( 1 ),
	Concatenate Worksheets( 0 ),
	Create Concatenation Column( 0 ),
	Worksheet Settings(
		1,
		Has Column Headers( 1 ),
		Number of Rows in Headers( 1 ),
		Headers Start on Row( 1 ),
		Data Starts on Row( 2 ),
		Data Starts on Column( 1 ),
		Data Ends on Row( 0 ),
		Data Ends on Column( 0 ),
		Replicated Spanned Rows( 1 ),
		Replicated Spanned Headers( 0 ),
		Suppress Hidden Rows( 1 ),
		Suppress Hidden Columns( 1 ),
		Suppress Empty Columns( 1 ),
		Treat as Hierarchy( 0 ),
		Multiple Series Stack( 0 ),
		Import Cell Colors( 0 ),
		Limit Column Detect( 0 ),
		Column Separator String( "-" )
Here is the example from the Scripting Index that illustrates how to get a list of the spreadsheets that are in a given wookbook.  From there one can select the last spreadsheet.
sheetList = Get Excel Worksheets( "$SAMPLE_IMPORT_DATA\Team Results.xlsx" );
Show( sheetList );
From there it is a simple matter to get the last entry in the list
jlmbs
This do not seem to be able to work. Here I wrote a code to pick up the xlsx file of interest, of which I would like to get the last worsksheet and open it into a data  table. Could you advise on how to move forward from the code below?
sheetList = Get Excel Worksheets(Pick File(	"Select xlsx file","$DOCUMENTS",{"Excel File|xlsx", "All Files|*"},1,0,""));
Show( sheetList );
After you have the name of last sheet and path to the file, then you can use Open() to open the file with only the last worksheet.
From Scripting Index:
Your code seems to work for me.  What issue are you having with it?  What JMP version and what operating system?
Show( sheetList );
Open(
	file,
	Worksheet Settings(
		1,
