Re: Is there an easy way to get the FWHM of a normal distribution curve from Distribution function ?
Created:
Nov 27, 2017 04:21 AM
| Last Modified: Nov 27, 2017 1:22 AM(9215 views)
| Posted in reply to message from ZY 11-27-2017
Apparently, the FWHM of a Gaussian is about 2.355 * sigma. So once you have an estimate of sigma from the Gaussian fit you are done (use 'Analyse > Distribution' then go to the 'Continuous Fit > Normal' option from the red triangle).
Created:
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '47695' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '47695') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '47695') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
