Phil_Brown
Is there a way to specify the x/y position of a TextSeg within a FrameBox?
Graph Builder(
	Show Control Panel( 0 ),
	Variables( X( :height ), Y( :weight ) ),
	Elements(
		Points( X, Y, Legend( 1 ) ),
		Line Of Fit(
			X,
			Y,
			Legend( 4 ),
			Degree( "Cubic" ),
			Confidence of Prediction( 1 ),
			Root Mean Square Error( 1 ),
			Equation( 1 )
		Dispatch(
			"Graph Builder",
			FrameBox,
			{DispatchSeg(
				TextSeg( 1 ),
				Set Text(
					"weight = -3850 + 197.7*height - 3.343*height² + 0.01906*height³
RMSE: 15.77  Tallest: Lawrence"
PDB
Re: Is there a way to specify the x/y position of a TextSeg within a FrameBox?
If you want to control the X and Y positions of text, you will need to add a Graphics Script to the FrameBox instead of to the TextSeg as the TextSeg is always going to appear in the top left corner.
Here is an example:
dt = Open( "$SAMPLE_DATA\Big Class.jmp" );
gb = dt << Graph Builder(
	Elements(
		Line Of Fit(
			X,
			Y,
			Legend( 4 ),
			Degree( "Cubic" ),
			Equation( 1 )
Report( gb )[FrameBox( 1 )] << Add Graphics Script(
	Text( Center Justified, {60, 40}, "Tallest: Lawrence" )
Justin
Here is an example:
	Elements(
		Line Of Fit(
			X,
			Y,
			Legend( 4 ),
			Degree( "Cubic" ),
			Equation( 1 )
Justin
Phil_Brown
Ok, indeed was aware of Text(). TextSeg being relatively new to me, I wondered about its limitations. Thanks Justin!
PDB
