cjackso21
Is there a way to make a script for a JMP Database Query?
In order to get traceability of our materials, I currently build a DB query to pull data from a table an Engineering table in our DB.   Can I create a script to do this?
Re: Is there a way to make a script for a JMP Database Query?
I believe that if you run your interactive database query, then once the new table is created, you can look in the Table Panel on the left side of the data table for the "Source" entry.  Right click on Source and select Edit and you will see the JSL required to perform the extraction using JSL
