Is there a way to control Cell labelling?
Is there a way to control Cell labelling? (e.g. label by percent in a Mosaic):
- We sometimes want to control decimals in the cell labels (67% instead of 66.6%)
- We often want to control the font size in the cell labels
- We often want to show the cell labels even for the tiny areas
- When the fill color is black (or dark), we would like the cell labels to be white
JMP 17, macOS
Re: Is there a way to control Cell labelling?
>>decimals in cell labels:
This can be done in the Graph Builder version of a mosiac plot.
>>font size in cell labels
a "kinda ok" way is to use CtrlShift+ and CtrlShift-, but this changes all the fonts everwhere. Might not be what you're looking for.
>>label even the tiny cells
I believe the Graph Builder version labels all the cells (it definitely labels cells that the Fit Y by X platform skips)
>>change text color
I don't have any ideas on this. Perhaps others will chime in.
- Using Graph Builder (rather than fit X by Y) does let us set the numeric format, so that is a solution to my first point.
- Crtl+ at least helps a little on my second point (but has odd behavior for small cells)
- Anyone have ideas on my last 2 points?
