nikles
Is there a method to get axis values from graph builder?
Hi.  I'm interested in knowing there is a scripting method to read the displayed values for an axis in graphbuilder and return them as a list.  IOW, is there a function or a message that can "get" the axis values from a graphbuilder reference or an axis box?  Something like: xval_lis = gb << Get X Axis Values.
For instance, suppose I have the following graph:
gb = Graph Builder(
	Size(513, 406),
	Show Control Panel(0),
	Back Color("White"),
	Variables(X(:age), X(:sex, Position(1)), Y(:weight)),
	Elements(Points(X(1), Y, Legend(1)), Smoother(X(1), Y, Legend(2))),
	Local Data Filter(
		Add Filter(
			columns(:age),
			Where(:age == {12, 13, 14}),
			Display(:age, Size(170, 96), List Display)
	SendToReport(Dispatch({}, "", AxisBox, {Select}))
Here, since the user has excluded certain ages using the local data filter, not all of the ages in the table are shown in x-axis.  In this case I would like a way to read off which ages are actually displayed in the graph.  This question applies only when a nominal or ordinal-type variable is used for the axis (no continuous variables).
I've considered the following scripting method:
1. Read the local data filter
2. Create a subset table of just the unfiltered rows
3. Use the Summarize function on that table to get my list of displayed axis values
ldf_str = ldf << Get Where Clause;  //ldf = reference to local data filter in gb window
clause = Parse(Regex(ldf_str, "Select Where\((.+)\)$", "\1"));
r = dt << Get Rows Where(Eval(clause));   //dt = ref to main datable
dtsub = dt << Subset(//Invisible,
	Selected Rows(0),
	Rows(r),
	Selected columns only(0)
Summarize(dtsub, xlev_lis = By(:age, :sex));
This method seems unwieldy though.  Is there a command that can "get" the axis values from a graphbuilder reference or an axis box?
gzmorgan0
Re: Is there a method to get axis values from graph builder?
@nikles,
Not sure of your user scenario, however, if the user is actively filtering, they can also change the GraphBuilder structure, different roles, etc. So a Filter Change Handler would be  more robust. Also note the Where Clause() does not capture the Inverse. The script and the TextBox of the Where captures the Inverse as a Not (!)
 Below and attached is a script that gets the Xticks and prints them to the Log when the filter changes.  Here is a screen shot of the embedded Log with comments (//) and extra line feeds.
Names Default to Here(1);
gb = Graph Builder(
	Size(513, 406),
	Local Data Filter(
		Add Filter(
			columns(:age),
//iftb = (report(gb)[PictureBox(1)]<<sib)[TextBox(1)]; //get handle to the textbox
ldf = (gb<<parent)<<child;
gbb = report(gb)[GraphBuilderBox(1)] ;
f = function({a}, {zz,aa1,varlist={}, _xvar_={}, i, _xticks={}},
      varlist = gbb << get variables;
      for(i=1, i<=nitems(varlist), i++,
        if(nameExpr(varlist[i][2]) == nameExpr(Role( "X" )), insertinto(_xvar_, varlist[i][1] <<get name) );
      zz= ldf << get filtered rows;
      if(isMissing(zz), zz= Index(1, nrow(dt)) );
   //check for excluded rows
      _excl = dt << get excluded rows;
      aa1 = AssociativeArray(zz);
      aa1 = Remove(aa1, Aslist(_excl));
      zz  = aa1<<get keys;
   //zz are the rows used in creating the graph
   //now use the Associative Array to get unique values
      _xticks = Associative Array( dt[zz,_xvar_], AsList(J(nitems(zz),1,1)) ) << get keys;
      print(_xticks);  //see the log
  f(1);
rs = ldf << Make Filter Change Handler( f );
Notes:
  • Line 20 is commented; it shows how to get a handle to the Where TextBox.
  • Key features of the function f used for the Filter Change Handler are the capabilties of the JMP implementation of Associative Array: multiple methods to define it;  to get unique values in a list; almost any JMP object can be used as a key.
  • Other key features are:  dt[ zz, _xvar_] is a list of row values, and ldf << get filtered rows.
gzmorgan0
@nikles,
gb = Graph Builder(
	Size(513, 406),
	Local Data Filter(
		Add Filter(
			columns(:age),
      zz  = aa1<<get keys;
  f(1);
Notes:
nikles
Thanks @gzmorgan0. It took a little time for me to grasp, but this is a nice solution. I appreciate the help!
