Is there a function to convert a character to its ASCII equivalent?
Is there a function to conver a character to an ascii number?
In the end I need to translate a character based column in data into its numerical equivalent.  They always happen to be 1 or 2 digits.  So effectively
"A" becomes 1
"Z" becomes 26
"AA" becomes 27
"AB" becomes 28
etc.
So say DIE_COLUMN = "CA"  I want to return 79
I've come up with the following thoroughly ugly formula... but if there was a char to ascii function I could do a lot better.   There HAS to be a cleaner way.
If( Length( :DIE_COLUMN ) == 2,
	Contains( "ABCDEFGHIJKLMNOPQRSTUVWXYZ", Left( :DIE_COLUMN, 1 ) ) * 26,
	0
) + Contains( "ABCDEFGHIJKLMNOPQRSTUVWXYZ", Right( :DIE_COLUMN, 1 ) )
Re: Is there a function to convert a character to its ASCII equivalent?
For the translation you are doing, your function works.  If an ASCII to Decimal function was used, the character "A" would return 65
Craige_Hales
Translating 2 character codes to a number is a good job for an associative array. You could create the aa with nested for loops. You might want to force lower case on the keys .
Craige
pmroz
This will do it:
die_column = "CA";
If( Length( DIE_COLUMN ) == 2,
	(num(hex(Left( DIE_COLUMN, 1 ) )) - 40) * 26,
	0
) + num(hex(Right( DIE_COLUMN, 1 ) )) - 40
You would need to uppercase die_column.  This works because A is ASCII 41.
