‘New to using JMP? Hit the ground running with the Early User Edition of Discovery Summit – register now, free of charge.
bzanos
Is there Lead () function in JMP?
There is Lag() function in JMP which is intended to provide data values from preceding records in a data set.
Is there Lead() function in JMP? or any similar function that I can use?
What I am currently doing is to sort a data set in descending order and then apply lag functions to create lead values. Afterward the data are sorted a second time, back to original order, before any analysis is done.
Jeff_Perkinson
Re: Is there Lead () function in JMP?
You can use a negative number in the second argument to lag to indicate forward lag instead of backward. For example the formula:
Lag(:a, -1)
results in this table:
a
Lag(:a, -1)
57
61
61
91
91
8
8
70
70
9
9
99
99
37
37
16
16
89
89
-Jeff
Jeff_Perkinson
Lag(:a, -1)
a
Lag(:a, -1)
57
61
61
91
91
8
8
70
70
9
9
99
99
37
37
16
16
89
89
-Jeff
bzanos
Thanks Jeff.
Being an Old Schooler, I have a tendency to use subscripting, so my formula for this would be
:a[Row() + 1]
David_Burnham
Have you tried using the Lag function with a negative value for the lag parameter?  Just a thought.
-Dave
