Is an embedded, interactive contour plot possible?
Hi everyone,
(I'm a JMP Pro 17 user). The project I'm working on specifically seeks to embed an interactive contour plot within a website GUI.
However, exporting a contour plot as Interactive HTML with Data specifically throws a message stating "Interactive HTML is partially implemented for this report." The log also states specifically "Interactive HTML: Contour plots are not interactive."
It feels a bit redundant to ask, and I recognize that there likely may not be a solution but: Is possible to export a contour plot and keep it interactive? Any workaround anybody has experienced if this is not possible?
Thank you!
Tony
Praveena
Re: Is an embedded, interactive contour plot possible?
Hi Tony,
Thank you for posting this question. Interactive support for Contour plots exported to Interactive HTML have been added in JMP 18.0 .
Thank you.
Praveena
Hi Tony,
Thank you.
