FN
FN
Introducing double quotes "" inside string in JSL (JMP)
I am not sure how to do the following:
my_string = "Hello
World!";
my_string = substitute(my_string , "\!"", """"); // This returns an error
// Expected
// "Hello
// World!"
Georg
Re: Introducing "" inside string
Where do you want to go with your string?
Inside JSL the escaped double quote (\!") is needed to let JMP know where the string starts and ends.
But if you display that string in a window, or elsewhere, it is like you desired.
names default to here(1);
clear log();
my_string = "\[Hello
World!]\";
show(my_string);
New Window( "String output window",
Text Box( my_string);
// Expected
// "Hello
// World!"
Georg
Georg
clear log();
World!]\";
show(my_string);
// Expected
// "Hello
// World!"
Georg
FN
FN
The idea was to write this string so JMP autogenerates a txt file.
Georg
sorry, I forgot,
and you can use function write, it does what you want.
write(my_string);
Georg
Yes, write(...) is much less confusing than print(...). Print adds quotation marks that make print pretty useless for printing strings, unless you plan to copy/paste them from the log back into more JSL, in which case all the escaping between the added quotation marks is useful.
pmroz
If I need double quotes inside a string I use the escape sequence \[your-string-goes-here]\.
For example:
World!]\";
write(my_string);
Output:
Hello
World!
