Interrupt a Script
Ok, this has happened a couple times to me and I'm not sure what to do in JMP.
I just asked JMP to make me a table with ~260,000 columns in it - JMP didn't like this, but it's not obviously against the rules of JSL so it tried. And tried. And tried - and half hour later I killed JMP (which I was sad about because I hadn't saved the script.
In SAS there's a button I can click to kill script execution if something is wrong. I can do the same in R. Is there some way to interrupt JMP's interpretation of my script while it's reading it?
pmroz
Re: Interrupt a Script
I've had some success hitting the ESC key.
I've tried that and it does nothing for me. Oh well - could just be that the mistakes I make are un-interruptable.
Just an example of a problem I created for myself this morning.
for(z=100,i >= 10,i--, ... );
This will run forever (and did) and crashed JMP - no amount of hitting ESC or bargaining with the computer would interuppt the infinite loop. Is there no way to terminate such mistakes?
