Hello @AlphaStarfish74,
Welcome in the Community !
Depending on which modeling platform you use, the coding of nominal factors can be different. You don't need to code the factors by yourself, you could have left the levels "Male/female" in the column "Gender", or "Cluster1/Cluster2" in the column "Cluster Lower".
In the Stepwise platform with the rules "Combine", the categorical variables are coded in a hierarchical fashion. The values you're seeing between brackets show the levels grouped in the term that most separate the mean of the response. In your case since you have only two levels for each of your categorical factor, you only see {L1-L2} with L1 and L2 the corresponding levels names of your factor.
Concerning the parameter estimate calculated, this represent the half difference in mean response when you go from level L2 to L1 on the considered factor (with the notation {L1-L2}). So in your case for "Gender", if you change the level from 1 to 0, this results in augmenting the mean response by 2x the corresponding estimate, so approximately 1,896.
You can find more information about the nominal coding of factors in the different platforms here : Models with Nominal and Ordinal Effects
And an example about nominal factor in model : Example of a Model with a Nominal Term
Victor GUILLER
