Interactive journals
I am working with JMP and need assistance with creating an interactive journal. My goal is to include a feature that allows users to select and highlight specific batches within a graph. Here are the details of the script and what I am trying to achieve:
Current Data Table(dt);
dt << New Column("Time Point Months", Formula(Round(:Time Point Days / 30.438), 2));
// Loop for each parameter
For(i = 1, i <= N Items(numPar), i++,
	col1 = Col Box("");
	col2 = Col Box("");
	col3 = Col Box("");
// Create all batches plot
	gb = Graph Builder(
		invisible,
		Size(500, 500),
		Variables(X(:Time Point Months), Y(:Result), Overlay(:Batch)),
		Elements(Points(X, Y))
	gb << Local Data Filter(
		Add Filter(
			columns(:Component, :Batch, :Source Table),
			Where(:Component == numPar[i]),
			Where(:Batch == {cyc, bat}),
			Where(:Source Table == dt_name)
	dt << Clear Select();
	gbb = Report(gb)[GraphBuilderBox(1)];
	gbb << Add Element(1, 1, {Type("Line Of Fit"), X, Y, Confidence of Fit(0), Equation(0)});
// Set Y axis
	minval = Min(
		:Result[dt << get rows where(
			:Component == numPar[i] & :Batch == cyc & :Source Table == dt_name | :Batch == bat
			 & :Component == numPar[i] & :Source Table == dt_name
	) * 0.95;
	maxval = Max(
	) * 1.05;
	maxvalts = Max(
		:Time Point Months[dt << get rows where(
	) * 1.05;
	gbb[AxisBox(1)] << Min(-0.1);
	gbb[AxisBox(1)] << Max(maxvalts);
	gbb[AxisBox(2)] << Min(minval);
	gbb[AxisBox(2)] << Max(maxval);
	gbb[AxisBox(2)] << inc((maxval - minval) / 10);
// Set Y axis label
	unitList = Associative Array(
		:Result Unit[dt << get rows where(
	) << Remove("") << Get Keys;
	If(N Items(unitList) == 1,
		gbb[Text Edit Box(4)] << Set text(numPar[i] || " [" || unitList[1] || "]")
	If(N Items(unitList) != 1,
		gbb[Text Edit Box(4)] << Set text(numPar[i])
// Set graph title
	gbb[Text Edit Box(1)] << Set text(numPar[i] || " vs. Time Point ");
	gbba = Report(gb);
	col1 << Append(gbba);
	gb << close window;
	For(k = 1, k <= N Items(cyc), k++,
		check = dt << get rows where(
			:Component == numPar[i] & :Batch == cyc[k] & :Source Table == dt_name | :Batch ==
			bat[k] & :Component == numPar[i] & :Source Table == dt_name
		If(N Items(check) > 0,
			gb = Graph Builder(
				invisible,
				Size(500, 500),
				Add Filter(
					Where(:Batch == {cyc[k], bat[k]}),
			gbb << Add Element(
				1,
				1,
			minval = Min(
					:Batch == bat[k] & :Component == numPar[i] & :Source Table == dt_name
			) * 0.95;
			maxval = Max(
			) * 1.05;
			maxvalts = Max(
			) * 1.05;
			gbba = Report(gb);
			col2 << Append(gbba);
			gb << close window;
			gb2 = Graph Builder(
				invisible,
				Size(500, 500),
				Variables(X(:Time Point Months), Y(:Difference), Color(:Batch)),
			gb2 << Local Data Filter(
				Add Filter(
					Where(:Batch == cyc[k]),
					Where(:Source Table == dt5_name)
			dt4 << Clear Select();
			gbb2 = Report(gb2)[GraphBuilderBox(1)];
			gbb2 << Add Element(1, 1, {Type("Line"), X, Y});
			l_idx = dt4 << Get rows where(dt4:Component == numPar[i] & :Batch == cyc[k]);
			ul = Min(dt4:HC[l_idx]);
			If(Is Missing(ul),
				If(
					Min(
						:Difference[dt << get rows where(
							dt5_name
					) == 0,
					minval = -5;
					maxval = 5;
					minval = Min(
							dt5_name
					) * 0.95;
					maxval = Max(
							dt5_name
					) * 1.05;
				minval = Min(
						:Component == numPar[i] & :Batch == cyc[k] & :Source Table == dt5_name
					-ul
				) * 1.05;
				maxval = Max(
					ul
				) * 1.05;
			If(!Is Missing(ul),
				gbb2[AxisBox(2)] << Add Ref Line(ul, "solid", "black", Char(Round(ul, 2)));
				gbb2[AxisBox(2)] << Add Ref Line(-ul, "solid", "black", Char(Round(-ul, 2)));
			gbb2[AxisBox(2)] << Add Ref Line(0, "Dashed");
			gbb2[AxisBox(2)] << Min(minval);
			gbb2[AxisBox(2)] << Max(maxval);
			gbb2[AxisBox(2)] << inc((maxval - minval) / 10);
			gbba2 = Report(gb2);
			col3 << Append(gbba2);
			gb2 << close window;
	results << append(ob = Outline Box(numPar[i], V List Box(col1, H List Box(col2, col3))));
	ob << close;
Edit (jthi 2024-08-26): Added JSL formatting
  1. Interactive Dropdown Menu: I want to create a dropdown menu that lists the unique batch values (:Batch column) in my data table.
  2. Highlighting Functionality: When a user selects a batch from the dropdown menu, the corresponding points in the graph should be highlighted.
  3. Embedding in a Journal: The dropdown menu and the graph should be embedded in a journal that can be saved and shared.
Byron_JMP
Re: Interactive journals
Did parts of this script work at some point?
Yes the script works :)
