  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
SaraGo
Interactive HTML files: Can I link them to the data in my JMP database?
Is there a way I can link a HTML file to my JMP table? Namely, every time the data in the JMP table are modified, the HTML file will be updated as well.
In case this is not possible, is there a different tool for (1) sharing files (e.g. histograms) with someone who does not have JMP on their laptop and (2) make sure these files are updated as the data in the (main) JMP table are modified?
Re: Interactive HTML files: Can I link them to the data in my JMP database?
We offer JMP Live for this purpose. You can try it at JMP Public.
Otherwise, you will have to write a script that detects a dirty data table, re-creates the JMP output, and saves the HTML to the same location. That sequence will not necessarily update the page as it happens, though.
