shiro
Interactive HTML Reports
I saw there is a way to create an interactive html report of jmp charts but I couldn’t found instruction on to do it, does anyone can help find a simple instruction?
In long story, I have a big jsl script that create charts and box plot from a very big data base, the script include filters, legends and ref lines.
When the user opens the window of the chart it takes a several seconds until the table open because it is very big, so I was thinking it will be better if I could create that window in an html so the opening of the table will happen before and the user won’t need to spend time on it.
I tried using a journal but it is not interactive so it is not a good solution.
if anyone have any idea I will be very happy to know,
thank you,
12 REPLIES 12
Re: Interactive HTML Reports
You can take a look at the Log (Ctrl->Shift->L).  It might provide information as to what is causing the report to not be interactive.  The interactivity is a subset of what is available in the regular product.  Development of additional capability is constantly ongoing, but will always be a more limited than the regular product.  If there are areas that are important to you that are not working, please tell JMP Tech Support ([email protected]) so that we can prioritize future work.
Thank you,
Brian Corcoran
JMP Development
shiro
can you explain where do I see the log? where should I press Ctrl->Shift->L? in the html window or in the script?
It should not matter.  If the log window does not come up, it means it probably is already up.  You can do View->Log from any menu to see it.
Brian
