See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
robot
Insert contents of Parse expression rather than variable name into New Script
I am looking to extend @Craige_Hales excellent answer from Insert contents of variable/expression rather than variable name into New Script by combining script, but have not worked out the syntax.  Any ideas to get this to work?
I am using JMP 18.1.2
dt = New Table( "My Table" );
e1 = Expr(
	Print( "Run some code." )
e2 = Expr(
	Print( "Run some other code." )
e3 = Expr(
	Parse( Eval Insert( "\[
	^e1^;
	^e2^;
// These work.
Eval( Eval Expr( dt << New Script( "Test 1", Expr( Name Expr( e1 ) ) ) ) );
Eval( Eval Expr( dt << New Script( "Test 2", Expr( Name Expr( e2 ) ) ) ) );
// This does not work.
Eval( Eval Expr( dt << New Script( "Test 3", Expr( Name Expr( e3 ) ) ) ) );
Re: Insert contents of Parse expression rather than variable name into New Script
Print your e3 to see what it contains
Name Expr(e3) = Parse(Eval Insert("
	^e1^;
	^e2^;
This possibly does what you are looking for
dt = New Table("My Table");
e1 = Expr(Print("Run some code."));
e2 = Expr(
	Print("Run some other code.")
e3 = Parse(Eval Insert("\[
	^Name Expr(e1)^;
	^Name Expr(e2)^;
Eval(Eval Expr(dt << New Script("Test 3", Expr(Name Expr(e3)))));
I would generally avoid using Parse as it is a nightmare to debug
e2 = Expr(
e3 = EvalExpr(
	Expr(Name Expr(e1));
	Expr(Name Expr(e2));
	^e1^;
	^e2^;
e2 = Expr(
	^Name Expr(e1)^;
	^Name Expr(e2)^;
e2 = Expr(
e3 = EvalExpr(
robot
Excellent!
