Individual confidence interval in prediction profiler
Created:
Nov 25, 2021 03:37 AM
| Last Modified: Jun 11, 2023 4:19 AM(1871 views)
Hi community,
I have two questions about using the individual confidence interval in the model fit platform:
Is there a possibility to display the individual confidence interval in the prediction profiler instead of the mean confidence interval?
Is there a possibility to display the individual confidence interval in the contour profiler? The aim is to see which conditions I can chose so the response is still within the individual CI (alpha: 5%).
It's a bit of a workaround, but you could always save the "Indiv Confidence Limit Formula" and use them to generate the profilers from the Graph menu. It'll create two profilers showing the high-and-low intervals. Is that an option?
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '439800' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '439800') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '439800') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
