Alec1293
Indicator Function Parameterization
I am working with a model in JMP that used Column 36 (Day/time series) as continuos, and co-%cover is continous baseline data, and column 35 is nominal and a treatment identifier of which there are 7 treatments. My question is the for the Prob >|t| what is that comparing? is it comparing eveyrhting to treatment 7 which is not listed as a term here or treatment 7 the intercept??
Alec1293
Re: Indicator Function Parameterization
I am interested in understanding this table better to better understand what it is telling me about this data.
See Help > Books > Fitting Linear Models. There is an entire section devoted to Indicator Function Parameterization in the chapter about Standard Least Squares Reports and Options.
