If you need to evaluate an expression "manually" [beforetaking the fist item from the result], use Eval():
In my opinion that creates code which is difficult to read and should not be used, just return the value and use that. If you know you want just a specific index (and know how many there are) you can use a list and "throw away" the rest
In my opinion that should result in an error (currently it is in my opinion unexpected behavior). My guess is that this works due to how Glue behaves (it returns the last result and it then gets evaluated)
Eval(
x = Expr(hello);
Print(x);
); // Eval(Glue(Assign(x, Expr(hello)), Print(x)));
vs (Name Unresolved: hello in access or evaluation of 'hello' , hello/*###*/)
Eval(
x = Expr(hello);
); // Eval(Assign(x, Expr(hello)));
I feel like this is what should always happen if Eval is being used in a case like this (attempt to evaluate Expr() -> fail evaluating it -> throw error). @EvanMcCorkle .
Created:
Jan 31, 2026 12:20 PM
| Last Modified: Feb 1, 2026 12:57 AM(1256 views)
| Posted in reply to message from hogi 01-31-2026
Ah, things get much clearer when we take a function which is defined with arguments:
g=Function({x}, {1,2,3});
x=g()[1] // doesn't work (uses the function itself and takes the first element)
x=g("")[1] // works -> 1 (runs the function - then takes the first element)
If there is a function with empty brackets: takethe function itself - don'tevaluate it.
If the function shows up with argument(s) inside the brackets: run the function! then take the first element of the result
especially if the function is send()
img = new image(Open( "$SAMPLE_IMAGES/tile.jpg", jpg ));
x = (img << get size)[1]; // works
x = send(img, getsize)[1] ; // same as this one
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '926389' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '926389') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '926389') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
