Increase size of data points in wafer map
nw = New Window("BSS_Wafermap",
	gb = Graph Box(
		framesize(xres, yres),
		X Scale(xmin, xmax),
		Y Scale(ymin, ymax),
		Fill Color("lightgray");
		Pen Color("Blue");
		Circle({0, 0}, 150000, "FILL");
		For(i = 1, i <= N Rows(pdt), i++,
			xleft = pdt:left[i];
			xright = pdt:right[i];
			ybottom = pdt:bottom[i];
			ytop = pdt:top[i];
			pcolor = color_list[1];
			If(pdt:defect_images_count[i] > 0,
				Pen Color("red"),
				Pen Color("Black")
				Fill Color("red"),
				Fill Color("Black")
			Rect(xleft, ytop, xright, ybottom, filled_rect);
		Title(" Lot: " || sdt:lot_id[p] || " Route: " || sdt:route[p])
The above is my JSL code I want increase the size of the points inside the circle and wnat to highlight the point if they have image attach to them in fdiffrent color. Could you please help me with this
Edit (jthi): added JSL formatting
Re: Increase size of data points in wafer map
If you wish to use Markers something like this is an option
pdt = New Table("Untitled",
	Add Rows(2),
	Compress File When Saved(1),
	New Column("x", Numeric, "Continuous", Format("Best", 12), Set Values([10000, 50000])),
	New Column("y", Numeric, "Continuous", Format("Best", 12), Set Values([3000, 70000])),
	New Column("defect_images_count", Numeric, "Continuous", Format("Best", 12), Set Values([0, 1]))
xres = 1000;
yres = 1000;
xmin = -150000;
xmax = 150000;
ymin = -150000;
ymax = 150000;
	gb = Graph Box(
		Pen Color("Blue");
		Marker Size(100);
		xx = [];
		yy = [];
		For Each Row(pdt,
			If(:defect_images_count > 0,
				mstate = Color State("Red");
				mstate = Color State("Black");
			xx = Matrix(:x);
			yy = Matrix(:y);
			Marker(mstate, xx, yy);
But you could also use circles which might give more flexibility
	gb = Graph Box(
		Pen Color("Blue");
		Marker Size(100);
		xx = [];
		yy = [];
		For Each Row(pdt,
				Fill Color("Red");
				Pen Color("Blue");
				Fill Color("Black");
				Pen Color("Black");
			Circle(Eval List({:x, :y}), 10000, "FILL")
And one more option could be to do most of this in graph builder, depending on what you are trying to achieve.
What issues are you having? Are you getting errors? Sizes of which points? You seem to only have rectangles inside your graph and their size is determined by your data table?
	Add Rows(2),
	New Column("left", Numeric, "Continuous", Format("Best", 12), Set Values([10000, 50000])),
	New Column("right", Numeric, "Continuous", Format("Best", 12), Set Values([3000, 70000])),
	New Column("bottom", Numeric, "Continuous", Format("Best", 12), Set Values([10000, 40000])),
	New Column("top", Numeric, "Continuous", Format("Best", 12), Set Values([30000, 50000])),
xres = 1000;
yres = 1000;
xmin = -150000;
xmax = 150000;
ymin = -150000;
ymax = 150000;
	gb = Graph Box(
		Pen Color("Blue");
			ytop = pdt:top[i];
				Pen Color("red"),
				Pen Color("Black")
				Fill Color("red"),
				Fill Color("Black")
			Rect(xleft, ytop, xright, ybottom, 1);
		Title("title")
Thanks a million for the clarification. Yes I have created the rectangle as I am not able to increase the size of the data points inside circle. If you could show me a way to plot the data points inside a circle of wafer map and highlight them based on criteria in different color or legend would be a great help. Thansk
	Add Rows(2),
xres = 1000;
yres = 1000;
xmin = -150000;
xmax = 150000;
ymin = -150000;
ymax = 150000;
	gb = Graph Box(
		Pen Color("Blue");
		Marker Size(100);
		xx = [];
		yy = [];
		For Each Row(pdt,
			xx = Matrix(:x);
			yy = Matrix(:y);
	gb = Graph Box(
		Pen Color("Blue");
		Marker Size(100);
		xx = [];
		yy = [];
		For Each Row(pdt,
				Fill Color("Red");
				Pen Color("Blue");
				Pen Color("Black");
Thanks a million Jthi It worked perfectly like I wanted
