In JSL, how to use a column name using a dynamic variable name list?
For example, I have a table dt with n columns, X1, X2, ..., Xn. I need to draw distributions for EACH column, X(i), like below (repeat n times):
Distribution(
Continuous Distribution(
  Column( :X1),
  Horizontal Layout( 1 ),
  Vertical( 0 ),
  Normal Quantile Plot( 1 ),
  Capability Analysis( LSL( 4 ), USL( 22 ), Target( 13 ) )
How can I use a loop to do this? I tried the following, but it is not successful :-(.
ColNameList = dt << Get Column Names(Nominal, String);
for (k=1, k<=n, k++,
Distribution(
  Column( :ColNameList),
  Vertical( 0 ),
Any good suggestion?
Thanks.
John
ms
Super User (Alumni) ms
Re: In JSL, how to use a column name using a dynamic variable name list?
I am not sure why you specify Nominal in <<get column names(). I would think that numeric and continuous variables are required In this context.
This should work:
dt = Current Data Table();
ColNameList = dt << Get Column Names( continuous ); //Capability do not work well with nominal columns
For( k = 1, k <= N Items( ColNameList ), k++,
  Distribution(
  Column( ColNameList[k] ),
  Vertical( 0 ),
