Importing summary statistics from excel to jmp
Is there a way of importing and plotting a set of observations that already has the summary statistics? I do not have the independent experiments values, just the summary of statistics.
I could from the standard deviation values obtain the range and add more rows for each treatment but I wonder if there is a way to avoid that.
Thanks!
Re: Importing summary statistics from excel to jmp
What do you want the graph to look like?  Are you asking JMP to regenerate the values that were used to create the mean and standard deviation for the Excel summary values?
