TC2
TC2
Importing CSV makes an empty table
Hi-
I'm following the import steps described here
https://www.stat.purdue.edu/~lfindsen/stat511/01_importing_text_files.pdf
and for some reason my tables are empty except for column names. I've tried different character sets (best guess, ASCII-US, macintosh) but the data fields are always empty.
I import files often, usually excel, but I'm at a loss as to why this is happening.
TC2
TC2
Re: Importing CSV makes an empty table
Ok, so I went in and used the import multiple function, and now the data table is populated. I used all the same settings otherwise, so it seems like a bug.
