Image loading from a hyperlink
Hey!
I want to perform image loading from a hyperlink, not data table as we have millions of images. Is this possible in JMP?
-Ilmari
Re: Image loading from a hyperlink
Just using Open() might work for simple cases
img = Open("https://www.jmp.com/en/company/media_10eeb65ad6a836677c8ff6b12e9d88dd4be7aa9e8.png");
nw = New Window("",
Event Handler column property is your best bet. Depending on how you wish the window to look like, use Open(), Web() or New Window() + some way to load the image (open, new image, new http request). If you have JMP19, this is in my opinion good use case for (global) tag.
nw = New Window("",
Or New HTTP Request
req = New HTTP Request(
	url("https://www.jmp.com/en/company/media_10eeb65ad6a836677c8ff6b12e9d88dd4be7aa9e8.png"),
	Method("GET")
data = req << send;
img = New Image(data);
nw = new window("",
My description might have been a bit vague: what I want is to load the image from a path to hover over label. Can this hyperlink be used for this in some manner?
Or, have an hyperlink in the hover over label that I can click and open the image
You could set up a "Click" behavior for the hover label, so that clicking on it will take you to a particular hyperlink:
