anders_bankefor
If statement that checks for exsisting data table
I'm trying to create a if statement that checks if a specific (table name is known) exists or not. If the table exists it should be appended to a journal. My code is as following:
//assigns the table to a variable.
Data Table( "Ber" ) << Subset( Invisible, (Selected Rows), Output Table Name( "Output" ) );
NC1 = Data Table( "Output" );
//Checks if the tables exists
If( try(Data Table ("Output"), TableExist = 0),
NC1 << journal
jrn << Append (Text Box ("Alla neg. prover har ett värde under 0.2"));
I've also tried with the following:
If( try(NC1, TableExist = 0),
NC1 << journal
Results:
Even though the table exists (no erros occurs while running the script) the table is not appended.
If the table does not exsist the text box is appended.
Why does this not work?
Kind regards
Anders
David_Burnham
Re: If statement that checks for exsisting data table
This should help you:
Try(
    Data Table("Output");
    tableExist = 1
    tableExist = 0
If( tableExist,
    show("exists")
    show("doesn't exist")
-Dave
pmroz
I use a function for this.  Once you've loaded the function, simply call it like this:
if (table_exists("Output"),
    // append to journal
    // don't append
Here's the function:
Function Name: table_exists
Description: Returns 1 if the table exists, 0 if not
Arguments:
table_name  Table to check existence of
table_exists = Function( {table_name},
      {Default Local},
   tbl_exists_flag = 0;
// Loop over all tables and see if this one exists
    num_tables = ntable();
    For (i = 1, i <= num_tables, i++,
        one_name = Data Table(i) << Get Name;
        if (one_name == table_name,
            tbl_exists_flag = 1;
                      break();    // jump out of the loop now that we found the table
    tbl_exists_flag;
);    // end table_exists function
David_Burnham
Try(
    tableExist = 1
    tableExist = 0
If( tableExist,
    show("exists")
-Dave
anders_bankefor
works like a charm, thank you for your help.
May I ask why it doesnt work when I make a combined statement of If and try? It seems to me that JMP contucts the operations (no error is generated) but it didnt conduct all of the statement.
Kind Regards
Anders
David_Burnham
The IF statement requires a condition that evaluates to true or false.  You are relying on the TRY function to do this, which is not its primary task, but it will return the value of the expression if evaluates.  But DATA TABLE("Output") gives a reference to a data table, it doesn't give a true/false answer.  In particular it doesn't give the answer true and therefore the IF expression never gets evaluated.
-Dave
pmroz
    // don't append
Arguments:
      {Default Local},
    tbl_exists_flag;
