Hamal22
If statement inside a graph with recalc option
I have a graph that I want to add target line per if statement (depends on user filters).
1. how to apply IF inside the graph code?
2. how to make the graph recalc and create the needed ref line?
example (the bold is not working):
Bivariate(
Y( :raw_value ),
X( :ah_attribute_value ),
Automatic Recalc( 1 ),
if (:FE_BE[N Row(dt)] == "FE",
Dispatch({},  "2", ScaleBox, {Add Ref Line( 10, "DashDot", "Red", "2 weeks", 2)}),
Dispatch({},  "2", ScaleBox, {Add Ref Line( 5, "DashDot", "Red", "2 weeks", 2)})
Dispatch(
"1",
ScaleBox,
{Label Row( Label Orientation( "Angled" ) )}
Dispatch(
"Bivar Plot",
FrameBox,
{Frame Size( 472, 387 ),Row Legend(
chamber,
Color( 1 ),
Color Theme( "JMP Default" ),
Marker( 0 ),
Marker Theme( "Alphanumeric" ),
Continuous Scale( 0 ),
Reverse Scale( 0 ),
Excluded Rows( 0 )
Re: If statement inside a graph with recalc option
Those are evaluated when the plot is created and they won't be re-evaluated later. You could (maybe) use graphic script to display the lines. Even easier could be to use Graph Builder and add extra lines to your data with extra columns to indicate the reference line values.
