BSwid
If row column value equals any values of any array then... What is the general form of this formal?
How do I write an If statement (or whatever the right function is) to evaluated when a row's column value = any value in an array?
Example:
If(    :ColToCheck == [Any of these values] , then 1, else 0 )
vince_faller
Re: If row column value equals any values of any array then... What is the general form of this formal?
Names default to here(1);
dt = open("$SAMPLE_DATA\Big Class.jmp");
dt << new Column("Some Check", FOrmula(
	//only doing !! so it's negates the output of contains (which is WHERE it is in the list)
	!!Contains({59, 63, 48, 70}, :height)
Vince Faller - Predictum
Use the Loc() function to check to see if any values are the same in a list when compared.  When doing this with a matrix, convert the matrix to a list.
z=[1,2,3,4];
loc(as list(z),2);
BSwid
Thanks.
I'm trying to do something like this.
#1 it expects a numeric.
#2 the return is coming back all missing values.  I tried data type expression and numeric, couldn't run distribution to see if there were values other than missing value.
cust = ["customer1","customer2","customer3"];
If( Loc( As List( cust ), :Name( "Ship-To Customer" ) ),
	1,
	0
//update 4/26/19
the orignal post did not have cust defined, instead it showed
z = ["customer1","customer2","customer3"];
That's why TXNelson is asking what is "cust"?
1. A matrix can only contain numeric values.  Therefore, the matrix z needs to be specified as a List, not as a Matrix
2. I do not know what "cust" is.
3. Is this a column formula, or open JSL code?
4. Loc returns a matrix of the positions where the testing value is found in the List.  Therefore, you need to determine if more than 0 rows were returned to determine if a match has been found.
Below are a couple of script examples that might help you out
// As a formula in a new column
dt << New Column( "is present",
	formula(
		z = {"customer1", "customer2", "customer3"};
		If( N Rows( Loc( z, :Name( "Ship-To Customer" ) ) > 0 ),
			1,
			0
// In open JSL
For( i = 1, i <= N Rows( dt ), i++,
	If( N Rows( Loc( z, :Name( "Ship-To Customer" )[i] ) ) > 0,
		1,
		0
vince_faller
BSwid
Thank you both.  @txnelson TX got me over the hump last night.  I just converted characters to numeric and it gave the desired result.
I think @vince_faller 's solution is what I'm looking for. I tried it with characters and it worked
	New Column( "Some Check 2",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
Formula( !!Contains( {"TIM", "ALICE", "JANE", "UDY"}, :name ) ) ),
// "UDY" is in there to verify contains will not return true for "JUDY"
Not directly.......that is why I use Loc().
