If Statement in For Loop Error
dg1
dg1
Hi! I am having trouble with putting my if statement in my for loop. I want my if statement to evalaute which elements in the array matches the word "Continuous", and store that column's data in a seperate array/list ( a suggestion for the best way to store coloumn data would also be helpful). I'd appreciate any help! Thanks.
Column Data = {};
 for(i= 0, i <= ncol, i++,
 	if ((Result[i] == "Continuous"),
 		ColumnData = Column(columnName[i])
Thierry_S
Re: If Statement in For Loop Error
Hi, I don't have time to test your script but at first glance I can see a couple of issues:
1) You do not define the table to be used by your script
2) Your call of "ncol" does not refer to any data table
3) You do not define the variable "Result" which you use as an array
4) Reference to a specific column content with "Column (ColumnName [i])" is not likely to work, maybe trying something like just "column[i]" might work better
5) Your assignment to "ColumnData" is not likely to work as you want because you are not appending each column content to the variable "ColumnData"
Thierry R. Sornasse
dg1
dg1
dt = Open(Example.jmp");
columnName = dt << Get Column Names (String);
ncol = 4;
Result = {"Continuous", "Continuous", "Categorical", "Continuous") // this is variable
ColumnData = {};
 	if ((Result[i] == "Continuous"), // i am getting an error for this statement
              // i want to store just column data and put it into a matrix, and perform operations on it
Thank you for your quick response. I apologize for not providng enough details earlier. Are you able to tell what is wrong with the code above? I appreciate your help.
gzmorgan0
@dg1 ,
Try
ColumnData = Column(columnName[i]) << get as matrix
