ns
ns
Unable to allocate enough memory in access or evaluation
I'm trying to use the Multivariate platform to perform a correlation between 6 time points (rows) across 73500 columns. My final goal is to output a  73500x73500 correlation matrix.
When I try to run it, I immediately receive this pop out message:
Unable to allocate enough memory in access or evaluation of 'List' , {/*###*/Estimation Method( 0 ), Matrix Format( 2 )}
What's the issue?
I'm using JMP Pro 13.2.0 on OS X 10.11. 2.7Ghz i5 and 16gb of RAM (1067 MHz DDR3).
Thank you
0 REPLIES 0
