There will be some limitations in model generation when you don't have access to JMP Pro. On the other hand, you can still do ARIMA modeling (if appropriate) and a simplified NN and partition tree. Another platform that might help is the predictor screening, under Analyze -> Screening. This could help to also identify which of the many factors are likely to be important.
Another thing you can try is in the Fit Model platform, to choose "stepwise" under "personality". This will also use different criteria to select which factors (and mixed terms) are needed and which aren't. Here, it helps a lot to have a pretty good idea of what kind of model to use. If you have lots of data, you could select all your factors and then choose response surface under the "macros" drop-down button. You just want to make sure your degrees of freedom are not reduced too far. If you know that there is some physical process governing the response, this can be a start in how to generate a model equation. One last thing you might want to look into is transforming your data before modeling it, especially if it's not normally distributed. Transforming the data can help the modeling process achieve a robust fit that has better predictive capabilities than it would otherwise.
As far the validation column goes, I know standard JMP doesn't come with the GUI to generate it, but here's some JSL that will generate N (I have it set to 5) validation columns that are stratified. Some models are sensitive to the validation column, even when stratifying on a certain response, so testing out different validation columns can be helpful in evaluating the robustness of the model.
For( i = 1, i <= 5, i++,
dt << Make Validation Column(
Training Set( 0.6 ),
Validation Set( 0 .2),
Test Set( 0.2 ),
Stratified Random( :Group )
In the above script, i runs from 1 to 5, so it generates 5 validation columns that are split 60% training, 20% validation and 20% test (you can change the values to what suits your data best), and it will be stratified random on whichever column(s) you choose in the :Group popup window. If you don't want to stratify, then you can replace that command with a random category formula.
JSL is a pretty easy language to code in, so if you have time, I highly suggest testing out some scripts to become familiar with it. I find it quite helpful when performing the same tasks on different data sets -- it helps to automate things. You can also check out the Scripting Index under the Help menu.
Good luck!,
DS
